- Dec 24, 2001
I didnt mention the model in the title as i dont want people skipping over this since they dont know anything about this model specifically, Ill take any and all help and advice as alot is just general questions.
The laptop is more of a Desktop replacement at 17.3" screen and 8lbs of lead in it.
Its the Toshiba Qosmio X775-3DV80 3D
http://www.toshibadirect.com/td/b2c/pdet.to?poid=2000010961
Some specs:
Intel® Core™ i7-2670QM processor
Genuine Windows 7 Home Premium (64-bit)*
NVIDIA® GeForce® GTX 560M (3D vision)*
1.5GB GDDR5 discrete graphics memory
8GB DDR3 1333MHz memory
1.25TB: 500GB (7200rpm, Hybrid 4GB Serial ATA) + 750GB (5400rpm, Serial ATA)
Blu-ray Disc™ Rewriteable (RE) and DVD SuperMulti drive with Labelflash®*
17.3" widescreen
FHD TruBrite® TFT LED Backlit Display (3D ready, 120Hz)*
1920x1080, 16:9 aspect ratio, Supports 1080p content*
NVIDIA® 3D VISION™ Kit (glasses, USB 2.0 type A to 5-pin mini-B cable)
It has pretty impressive specs to say the least, Great for the money even tho it was expensive, It could have cost alot more.
Generally id never spend this much on a laptop, But ive found over the years that if you dont get the parts in it when you buy it you most likley cant upgrade much later so your stuck with your decisions for the life of the LT.
Ill try and number questions when they come up as i type, And i hope you dont mind ill give my impressions of the LT as i go also.
My only upgrades i can see me doing is going too 16GB of ram soon and possibly a full on 128GB SSD drive to add with the 7200rpm sata Hybrid drive with 4GB of SSD built in. Even tho it holds two hard drives i dont think it can do raid that i know of. But i guess i need to go threw the Bios soon.
Past that I cant see much else being done, But i suppose i can upgrade the video card if id like. But im sure that would be untested teriitory in if its possible as im sure not many people will attempt that, But it runs any game now on all maxxed out settings.
1. First question is about the 3D system, Ive found it to be amazing. But has a learning curve also. It seems to upconvert non 3D games so far, But ive had no luck with Netflix and streaming content. I dont have any DVD's or BlueRays on hand to test, But will these upconvert like the games do even tho they arent 3D? I have some im gonna try and borrow and test, But i figured its worth asking.
2. At what point would you see that i need to invest in more ram? When i start going over 50% of the installed ram being used consistently or wait for 75% to be normal?
3. How much priority would you put on swapping out the second HDD and putting a good SSD on it and use the 7200/SSD hybrid as storage?
4. Overclocking and underclocking, Ive always been a user of RMclock. But it dont work on the Intel® Core™ i7-2670QM
I did get temp info for the CPU with "RealTemp" sofware, But it gives me no control of the cpu. Is there anything out there that may work on undervolting and overclocking of the i7-2670QM cpu?
5. CPU throttling, In realtemp you can test the cpu cores with 8 copies of prime 95 all at once, But ive found it to hit 80c on the cores and im almost positive it starts throttling the processor to bring temps down as ive seen the MHZ drop as low as 1600mhz.
Ive got an old laptop cooler under it, But i ordered a new much better one and an extra large 120mm fan to add also in an attempt to get things as low as possible temp wise. Im really reluctant to go in and take it apart so i can look at improving the cpu cooling with better compounds and adjustments.
Granted there is NO way that in normal use i would be able to run all 8 threads at 100% for any amount of time.
Any advice here on this one?
I can see threw CPUZ that it undervolts all on its own down too .78v to the CPU.
6. GPU control and overclocking software anywhere? Its the NVidia GTX560M card.
Over all i LOVE the laptop, Its almost over the top especially while gaming in 3D and everything is almost instantaneous when you do any opening or closing and work due to all the power it has. An SSD drive would make it insane tho so ill eventually be looking into that.
7. Speaking of SSD, I see they have SATAIII 3gb and 6gb buss speeds, How can i tell if i can take advantage of the 6gb speeds or not? Is that mainly on desktops with fast expandability slots that mine wont have?
I think thats it, Id appreciate any help or advice you have,
Some specs:
17.3" widescreen
