This'll definitely be hard to replace the battery or HDD.
Perhaps it's bad form to quote myself, but the issue has apparently been officially clarified. The battery will not be user replaceable, instead it costs $129 and a trip to an Apple service center.
Now, that'll prolly turn out to be similar to the "non-user-replaceable" battery in the iPod, whereby hundreds of blog pages will illustrate how to do it and hundreds of eBay auctions will sell the required batteries, but it's still a pretty lame move on Apple's part, regardless.
Actually it only involves removing a few screws from the bottom. This is the same as servicing a Dell, except that there are fewer screws. This has been covered a few times here and on other sites. The HD and Battery are easily accessible by anyone with a torx screw driver set.
All that and still no tablet functionality.
I still don't understand tablets. Every time one comes out, people go "ooooh" and then "man this sucks." It's just a bad idea until they're as light and reliable as pen and paper. Thats fine and all if all you want is a giant PDA, which is really all a "tablet PC" ends up being used for anyways when it's not being used as an overpriced laptop.
Its the lightest OS X portable, So if thats what you want, you pay up.
The ppl buying it DONT WANT a Dell with windows.
I dont see a problem here.
If Apple wanted to compete with 600$ laptops, they would have made a 600$ laptop. But they dont. So they didnt.
Totally different Target audience.
it is made for a very specific market, if it doesnt appeal to you, it is not for you.
Indeed. If you don't want a Mac, you don't want a Mac. Some people think Audi makes great cars. When I see one I say, "man what an expensive, ugly, piece of junk made by Volkswagen." Does that make them bad cars?
One nice thing over other sub-notebooks in that weight class is that it uses a full CPU and not an ULV processor. Should it have more USB ports? I think so. Version 2 will probably have that. They did this with the original iBook and people flipped out about it too but it never made that machine "unusable" by any means. Some smart company will make a USB hub that matches the computer's lines and basically becomes it's conjoined twin.
I haven't used ethernet on a laptop for years. Also people complaining about the lack of a media drive should just go for a regular MacBook, thats why it's there. Like they said, it's target audience is different. If all you do is take notes all day, work on spreadsheets, etc... anything not needed a DVD drive then you'll probably not have an issue. If your laptop needs to do everything your desktop does, no subnotebook on the face of the Earth will work 100% to your needs. Thats not what that type of computer is for.
Apple's had a lot of success with this formula so they know what they're doing. They did it throughout the 90s with the Powerbook Duo Series and the 2400 (albeit the 2400 had a CD-ROM). It'll probably stay in the lineup for a couple years and then be replaced with a smaller, thinner, lighter MacBook or Macbook Pro (a la the 12" Powerbook) as technology allows. I've told people for years that they'd make something like this again so I got a nice "A-HA!" moment when it came out .
