- Sep 25, 2015
So...I bought ATMINSIDE's GA-Z87N-WIFI mITX motherboard for this build:
Case: old emachines mATX case
HDD: from old machine
PSU: from old machine (ATNG 800W, Bronze)
MB: GA-Z87N-WIFI mITX
CPU: Xeon E-1230V3 (LGA 1150)
Cooling: Intel Stock
Memory: Crucual Ballistix Tactial DDR3 (9-9-9-27) 2 x 8 GB
GPU: from old machine (EVGA GTX 960 mini)
The first thing...the Xeon chip is smoking fast and smooth (4 cores, 8 threads...3.5 GHz). A lot cheaper than the LGA1150 i7 chips.
Does not have an embedded iGPU. This is a good thing as I already have the graphics card...good thing until you are troubleshooting your build for a blank screen at boot...because you have the monitor plugged into the motherboard and not the graphics card...doh! (Only 15 minutes - hehe).
Finally...for those of you that have ever done a build this small...when I was done I sat back and was like "How did I manage to fit everything in there? How did I manage to get everything plugged into the motherboard???")
A final note: For those of you who run headless systems like this one is now, this little HDMI plug is great:
http://www.amazon.com/gp/product/B00JKFTYA8?psc=1&redirect=true&ref_=oh_aui_detailpage_o05_s00
You plug it into the HDMI port, and you can select any resolution you want from 800x600 to 4088x2304.
