As promised....
The new Sprocket.
Here she is in all her fully dressed splendor.
I really tried to avoid making the case look like it had been modded, but some additions were unavoidable.
The hole in the sidepanel is for a 120mm fan (visible later).
The upper bays house two optical drives with black alloy CoolerMaster faceplates and a fanbus ( soon to be replaced with a custom panel).
In the floppy bay opening is a LED temp readout (cobbled from a HDD cooler, it cycles between two sensors- currently reading case ambient and radiator exhaust) and right next to it is my "Clear CMOS" button.
Centered below is the volt guage from a Volkswagon GT-I, it reads from the +12v line on the PSU.
At the bottom ( below the Gateway logo), are the USB ports that I added and in the base is the floppy drive (which I was forced to install so I could load SATA drivers and now think is pretty cool down there).
I'm trying to work out a door to cover the USB ports but haven't come up with anything I like yet.
Movin on ( or
in, actually...)
The full side view.
This shot gives a good impression of how tall this case is (23").
Above the motherboard, where the radiator now sits, is the original location of the PSU.
In it's stock form this case had a caddy above the PSU which would house three more HDDs.
I removed this bay ( it was screwed in, very nice) and relocated the PSU to the top of the case.
Trimming out the now vacant PSU opening allowed me to mount two 92mm exhaust fans on the back wall which pull air through the radiator ( and from the case in general).
The crossbrace which holds the side 120mm fan ( intake) used to be higher up, I drilled out the rivets and drilled/tapped it for 6-32 screws and moved it down the case.
Originally this was to accomodate the SilentTower HS I was trying, now it positions the fan to blow over the passively cooled video card and provide outside air for the fans on the north/southbridge.
The grey plastic box in the lower right corner holds the modified water pump and serves to muffle the pump noise ( it works!) and also to contain any possible pump leaks. This box is an electrical junction box from Home Depot.
Two semi-closeups...
Again, I must apologise for my lack of photography skills, hopefully you can glean any detail info you like from these shots.
I love this case.
The steel is probably 25% thicker than more modern cases and the ABS front bezel is correspondingly sturdy.
Fit and finish is superb and the design is growing on me daily.
Airflow is very good, the design of the front bezel is far more condusive to air intake than most modern "performance" cases. The center section that the volt guage is mounted on stands proud of the rest of the bezel by about 1/2", kind of like that weird obelisk on the front of the WaveMaster case, ( not easily visible in my bad photos) and is completely unobstructed behind, so intake is excellent.
Admittedly, these are idle temps, but they do show that this case and configuration works pretty damn well.
The absence of exterior holes makes Sprocket very quiet ( no, NOT silent, but very tolerable).
Attention-***** that she is, Sprocket craves all comments/criticisms, so have at her.
