- Jul 12, 2003
I'd like to place a window in my case which I was planning to make out of plexi. I should have no problem cutting the window to size and getting it secured into the case. The problem I have is I'm currently running a 120mm side fan and I need to get a 120 hole cut into the the plexi for the sidefan to go in. What the best way to do this? A dremel? Magic pixie dust? All ideas welcome.
