- Nov 22, 2003
- New York City
More Gentoo Stuff: GCC-3.4.4 Now Marked Stable on x86
Gentoo Linux Upgrade Guide
http://www.gentoo.org/proj/en/base/x86/gcc-upgrading-guide.xml
Here's the summary, pretty much:
Or for the lazy:
Go have a good weekend, since you'll be recompiling your whole system.
3.4 marked stable on x86
Posted on December 2, 2005 by Mark Loeser
GCC 3.4 has finally been marked stable on x86. No one will have their compiler automatically switched to gcc-3.4 after it is installed, so you can handle the migration to using it as your system compiler when you have time. To assist you in the migration we have made a GCC migration guide.
For support issues, #gentoo is the place to receive help. Bugs found in the course of this upgrade should be filed under the "Gentoo Linux" product, and "GCC Porting" component on Gentoo's Bugzilla.
Code:
# emerge -uav gcc
# gcc-config i686-pc-linux-gnu-3.4.4
# source /etc/profile
# emerge -1 sys-libs/libstdc++-v3
# emerge -e system && emerge -e world
# emerge -aC =sys-devel/gcc-3.3*
Or for the lazy:
Code:
emerge sync && emerge -u gcc && gcc-config i686-pc-linux-gnu-3.4.4 && source /etc/profile && emerge -1 sys-libs/libstdc++-v3 && emerge -e system && emerge -e world && emerge -C =sys-devel/gcc-3.3*
