- Apr 21, 2001
- Den Haag, The Netherlands
I have received my 2 d-tek heatercores the other day but it has no mounting point.
Since I won't be using a push/pull system, just a pull system on both heatercores.
I'm using the Yeong Yang YY-B420 case which has 2 120mm fan holes in it's front-left.
The heatercores will be mounted on the inside of the case behind two 120mm holes. Both holes have 4 mounting holes for a fan.
I have 2 shrouds I will be using to put the fan's on. But how do I mount the heatercores? Any idea's?
Thanks in advance.
Thanks in advance.
