ok i just got my wc-301 and im leak testing i think i cut my lies to short tho but i'll know when i starp her on but i still got some more but im gonna go to home depot and get some more lines any kind i should get over the outhers?
my question is this when mounting the cpu block for k8's the screws are to small to grab the plastic and theres no nuts inside the base mount on the mobo.
could i use the p4 mount that came with it? it fits but im worried about behind the cpu those pins touching the mount. should i use that and put a few coats of eletrical tape over them for good luck before i install it?
thanks for any and all help.
