Hey... just got this pump/rez combo
modmymods.com
came with a alphacool vpp755 pump installed. Just wondering is it possible to control the speed of the pump? The last pump rez combo i got had buttons etc. This one only has the sata power and a 4 pin plug with two wires. I was told this was the pump controller cable and I plugged it in to the cpu fan header is this right? how to control the pump? seems to work not the most powerful but its doin it... thanks in advance1!!
ps... on a side note im using the old school CoolIT TEC coolers just for the cpu. Ive always put them before the cpu so it has cool water going to it? is this right or should the TECs go after the cpu? cheers
Alphacool Eisfach - Single Laing D5 incl. Alphacool Eispumpe VPP755 - Dual 5,25 Bay Station Reservoir (13304)
div class="product--description" itemprop="description" pstrongThe step towards perfection/strongbr /This new Alphacool dual 5.25" bay reservoir comes with a preinstalled Alphacool VPP755 Eispump./p pThe brushed plate provides an optical f
