I will have to agree, I hated mine so bad I took it out of the case. But personally I think that if it had the right VMODS it could take off real good. If you work with it you can probably get what your trying 4.
It is real picky with ram, & other settings but I finally got mine to 250 HTT but it took alot off learning.
By the time you get it going you will probably settle 4 less than you started out with.
Acouple off things I can tell you though.
Use 3 & 4 sata connectors, go 3x on LDT, max the voltage out on everything(except AGP), use the first & third ram slots, use single sided ram, forget BH5 or BH6 unless you VMOD, & if you cant get it to do much get the latest beta bios. I have it here if you cant find it. Also it will not install raid if you use W2k unless you have the one with SP4 built in. If there is a way to add SP4 when loading I dont know it but there may be away.
Also the first few settings about agressive timings & performance CPU, may be called something differant but leave them dissabled. Good Luck & if we can help just post.
