- Nov 5, 2017
MY FIRST RYZEN BUILD WITH POP_OS AN VMWARE WITH WIN10PRO
(UPDATE) CUSTOM CABLES FROM CABLEMODS arrived
an installed along with the fans in this config front 3 Noctua F12 intake an the top 2 Noctua A14 exhaust on 1
Silverstone 8-Port PWM Fan Hub/Splitter
an the last Silverstone 8-Port PWM Fan Hub/Splitter & Noctua F12 on the aio is in pull config
with custom filter mesh over the aio an unused pci slot ports for good air flow an good dust control
with a brush ill touch up the yellow were i missed later
ill also update pix of setup on desk when the 2nd AOC C24G1 24.0" 1920x1080 144 Hz Monitor arrivers later this month along with exturnal burner connected the
Asus BW-16D1HT Blu-Ray/DVD/CD Writer
i might also replace the
Redragon K552 Wired Gaming as there dosent seem to be a good rgb control for it on pop_os
i might go with the CORSAIR K55 RGB PRO as thers a workable app in the pop store for the icue
............................OH AN YES I KNOW THE MONITOR IN PIX IS NOT THE AOC this my asus the i use for builds an testing the good aoc is back on the desk not the kitchen count
THE DARKBLADER X5 IS STILL IN PROGRESS MOREE LATER
benchtest an proformence run details later too
HERES LITTLE BEAST PIXS
https://pcpartpicker.com/b/LFDxFT
the two 120mm noctuas in this pix were replaced with the 140mm in previos pix an pulled closer
aftermarket heatsink inplace of original the riitop houses a 2nd 500gb nvme drive (any thoghts on wheither i should run in raid mode for them)
im going to use a brush to paint the spots i missed with spray cans a touch up the fan frames an ram heatsinks later
