Here is a copy of my post at the RamGuy Corsair Forums> I figured I would post here, too to see if you guys know anything I don't.
Thanks a bunch!
Help!
I have been having a helluva time with my ram and board combo. My 2-PC3500C2 sticks will not run at rated speed on my Epox 8rda3+. I get MANY errors in memtest on test #5 when in dual channel at 200 . I have to set it to 2.5-3-3-7.
Here is what I have done so far:
Epox 8rda3+:
Tested (test #5) memory individually @ 200 2-3-3-7 (as rated): 0 errors
Tested both sticks, single channel @ 200 2-3-3-7: 0 errors
Tested Dual Channel @ 200 @ 2-3-3-7: 100's of errors
Tested Dual Channel @ 166 @ 2-3-3-7: 0 errors
Abit IC7G:
Tested Dual Channel @200 and 217 @ 2-3-3-7 in my P4 machine: 0 errors
Why won't the rated timings work in my Epox board UNDERclocked even?!
I may need to bios update though I checked all of them and none of them addresed this sort of issue.
All test were done at default voltages (the dimms showed up as 2.7V which I figured was more than adequate) with my Athlon 1700 running at 200*5 or 200*7 (to eliminate the processor as a variable).
Any help would be appreciated.
Thanks a bunch!
Help!
Epox 8rda3+:
Abit IC7G:
