N00b's Guide to Conroe Based Performance Computing and OC Results
New Member - NEED HELP OC Asus P5P43TD motherboard
I would first like to say hello. I am a new member and I Need help with overclocking my CPU in Bios
the specs for my computer are as followed:
Asus P5P43TD Motherboard
Intel Pentium Dual-Core E6500 Wolfdale 2.93GHz 2MB L2 Cache LGA 775 65W
Dual-Core Processor
Tech Spec
Core
Wolfdale
Multi-Core
Dual-Core
Name
Operating Frequency
2.93GHz
FSB
1066MHz
L2 Cache
2MB
Manufacturing Tech
45 nm
64 bit Support
Yes
Virtualization Technology Support
Yes
Voltage
0.85V – 1.3625V
Thermal Design Power
65W
Kingston HyperX 2GB 240-Pin DDR3 SDRAM DDR3 1800 (currently running on board
at 1643mhz)
2GB
Speed DDR3 1800
Cas Latency 9
Voltage 1.7V - 1.9V
ECC No
Buffered/Registered Unbuffered
HIS H467QR1GH Radeon HD 4670 1GB 128-bit DDR3 PCI Express 2.0 x16
Chipset Manufacturer:ATI
Core Clock:750MHz
Stream Processors:320 Stream Processing Units
Effective Memory Clock:1600MHz
(which is clocked with their catalyst)
Western Digital Caviar Green WD5000CSRTL 500GB 7200 RPM 16MB Cache SATA 3.0Gb
APEVIA ATX-AQ700W-BK 700W ATX12V / EPS12V SLI Ready CrossFire Ready Power Supply
I am running Windows 7 32bit and I also tried to install the Turbo Key but it does not work on my system.
I don't know if this would help at all but if someone could inform me I would appreciate it. I heard this can get up to 3.66GHz if you up the FSB to 333 but I am looking to only go to 3.52GHz.
I hope someone could walk me through the BIOS settings so I could tweak everything correctly & ensure stability.
I have built some computers before but never had the opportunity to overclock, hopefully someone could walk me through the steps. Thanks.
Mr.Weston
