- Jun 23, 2012
My Sabertooth 990FX will not boot, no screen at all. Black, dead to the world on video. CTRL + ALT + DEL will restart system while it is running and without the video. I am give a 'system' check short beep to confirm the system is working however the 'boot device' LED stays on. It was working perfectly fine and shut down correctly on 6/21/2012.
I'm currently also looking for a replacement in this forum:
http://www.overclockers.com/forums/showthread.php?t=710606
Until then I would like to boot my system at least.
Here is what I have currently:
ASUS Sabertooth 990FX AM3+ AMD 990FX SATA 6Gb/s USB 3.0 ATX AMD Motherboard with UEFI BIOS
http://www.newegg.com/Product/Product.aspx?Item=N82E16813131736
CORSAIR Professional Series HX1050 1050W ATX12V / EPS12V SLI Ready CrossFire Ready 80 PLUS SILVER Certified Semi ...
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139034
CORSAIR Vengeance 8GB (2 x 4GB) 240-Pin DDR3 SDRAM DDR3 1866 Desktop Memory Model CML8GX3M2A1866C9R
http://www.newegg.com/Product/Product.aspx?Item=N82E16820233240
LITE-ON Black Internal 12x BD Combo SATA Model iHES212-08 LightScribe Support
http://www.newegg.com/Product/Product.aspx?Item=N82E16827106451
AMD FX-8120 Zambezi 3.1GHz Socket AM3+ 125W Eight-Core Desktop Processor FD8120FRGUBOX
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103961
XFX Double D HD-695X-CDFC Radeon HD 6950 2GB 256-bit GDDR5 PCI Express 2.1 x16 HDCP Ready CrossFireX Support Video
http://www.newegg.com/Product/Product.aspx?Item=N82E16814150549
Western Digital Caviar Black WD1502FAEX 1.5TB 7200 RPM 64MB Cache SATA 6.0Gb/s 3.5" Internal Hard Drive -Bare Drive
http://www.newegg.com/Product/Product.aspx?Item=N82E16822236117
Microsoft SideWinder X6 Black Keyboard Win USB English
http://www.newegg.com/Product/Product.aspx?Item=N82E16823109063
Razer Mamba 2010
Code:
I have tried to Reset CMOS correctly.
I have Windows 7 Ultimate.
HDD Works 100%.
Sometimes booted after this problem after trying all steps repeatedly.
All components except MoBo work.
Monitor works.
HDMI output wont work either.
Followed mem test directions.
Replaced battery.
Bios was the latest, Version 1208, 2012
Razer Mamba 2010
