- Dec 31, 2004
- Australia
I'm building a new Rig for COD4 and the recommend spec are:
OS: XP or Vista
Processor: 2.6ghz Pentium IV or equivalent (3.2ghz recommended for Vista)
RAM: 1024mb (1536mb recommended for Vista)
Video Card: DirectX 9-compliant Shader 3.0 card with 128 MB of DDR Video Memory (256 MB recommended) AGP 8x or PCI-Express x16
Sound Card: 16-bit DirectX 9-compliant sound card
DirectX9 for XP and 10 for Vista, 8 gigs HD space + 600mb for swap file.
Supported chipsets:
Nvidia Geforce 6/7/8 series
ATi X800 or higher
So I've decided on the E6850 CPU, an 8800GTX card, 2Mb Ram, and some Seagate SATA drives (I think). I prefer a case with a side window, good cooling, removeable HDD bays, Removeable M/b tray, and the space to easily fit all the components so the cabling will not be messy. The PS needs to be able to support the above specs.
So what's your recommendations?
Thks!
OS: XP or Vista
Supported chipsets:
ATi X800 or higher
Thks!
