- Dec 4, 2008
Hello everyone,
Thanks for taking a peek into this thread.
Please advice which of the 2 choices below that I should keep.
In both cases, Core Speed are the same, Vcore at default voltage (auto), Ram at default as well.
ASUS P5E-VM HDMI mATX
The 1st choice runs at default 9x multiplier but DRAM Frequency is only 370Mhz which is below its RAM speed. Couldn't raise higher for stability.
On the 2nd choice, I was able to raise DRAM Frequency to 418MHz but had to drop its default multiplier to 8x
1st choide:
Q6600 @ 3.33GHz @ 9 multiplier
FSBRAM= 1:1
DRAM Frequency= 370
FSB= 1480MHz
4GB Partriot PC6400 800MHz @Default 4-4-4-12 / 2.2Volts
2nd choice:
Q6600 @ 3.34GHz @ 8 multiplier
FSBRAM= 1:1
DRAM Frequency= 418
FSB= 1672MHz
1st choide:
FSBRAM= 1:1
DRAM Frequency= 370
FSB= 1480MHz
2nd choice:
FSBRAM= 1:1
DRAM Frequency= 418
FSB= 1672MHz
