- Jan 10, 2002
- Dublin, Ireland
Question 1:
I'm adding a big side window (almost the whole side panel) to my case, and etching a big design into it. I want to light up the design so was thinking of putting lighted string around the edge of the window, but don't know which of these is brightest:
A) Neon String
B) Electroluminious Strip (EL Strip)
C) UV Florescent PVC Cord
Do you know which one?
Question 2:
I am also replacing the white plastic front of my PC with the same material as my window, and painting one side of it black, then etching a design into it. I want to paint this etch in UV paint and then attach a UV light into the middle of the front to light it up. As the UV light will be below the design, will only the bottom of the front etch light up or will the whole thing?
Because:
A) if it doesn't, then I'll need to think about another method of lighting.
b) if it does, I need to find the best way to incorporate a UV light into a sheet of plastic.
Any suggestions or anything about my plans are welcome, especially answers.
s.
A) Neon String
Question 2:
Because:
s.
