Thank you for your response. Ideally I would want my current system to be placed in this new case. Honestly I do not really know what components I will put in it. As far as budget, the lower the better. I would love block and fans to be below $100 or around that amount for mid-tower. I believe full-towers would be more expensive, so anything that is a of a comparable quality(which will be more expensive) to mid-towers at $100 budget. I am interested in full-towers because it is not as crowded inside.
I will give some details and a background of what made me go shop.
Over all my Rosewill Galaxy-02 case is very noisy. I did not modify it or put any silent fans in it to reduce noise. Always wanted to upgrade it, but I would skip the upgrade.
My computer does not boot. I saw a spark in my surge protector when the power cable from my Samsung printer got stretched and almost pulled out from the surge protector when I moved the printer. I am not electrician, but I think because the power cable was pulling out of the surge protector socket the printer tried to draw more power through less metal contact and it shocked the rest of connected devices to the surge protector. My computer block, monitors and speakers turned off and then turned on for a second, but then the computer block turned off and never booted again. Another version is that it was rainy outside and the electrical grid got hit by lighting in that exact moment and that caused my mother board to die, but I did not have my computer equipment damaged in the last four years since I bought it. The surge protector seems to continue working, but I will probably throw it out. Whichever the case, it seems like I need a new motherboard, but it is hard to find a new z97 mother board or any other motherboard that would work with i5 4690k with 1150LGA socket. Despite motherboard not being responsive, my power supply fan seems to work when I connect green wire to the ground if I am correct that means that the power supply is alive. Not sure how often motherboards die while power supplies survive. Also, I did not smell anything burned when the computer block turned off. I do not know which other parts died as I can not test or do not know how to test them myself except for the test I described above for the PSU. If I am not mistaken it is the mother board since PSU is working(according to my test), motherboard does not beep, which is next in line for testing(according to what I know). Though the mother board can power my SD card reader, which gets an LED glowing when it is connected to the motherboard. If there is a known guide in what sequence and how to test system for faulty parts, please direct me there. That would be really appreciated.
Which ever the case, I already took apart my computer block. And now since I need to put it back with a new motherboard or motherboard and CPU I want to get first of all a new case, which should be as silent as possible for the least distraction during my work or studying. Second I want to get a UPS unit, which would protect my equipment in the future. Third, I need to put other parts inside, and which survived I do not know. I will either find and by a new LGA 1150 motherboard compatible with my i5 4690k or I will get something cheap like Ryzen 1600 $80 (it seems like it is comparable to i54690k since it is newer) $80 and a mother board (probably $130, have not looked for one yet). It is also possibility that my ASUS 970 card died, because the annoying LED that would not turn off when the computer was off does not glow anymore. The LED might not glow because mobo is dead, because PSU does not feed it, or it burned. In that case I have my older GTX 760. I am not sure if it would be able to run my 43" LG and 23" Dell monitors together even though it seems to have HDMI and DP ports. So I might need to upgrade the card to something comparable to what I had for the least price.
Also, I bought my system in 2014 for gaming. Now I rarely game, but want something that is still powerful or comparable to what I had. I went with Intel at that time because FX CPUs from AMD were much hotter and would need a replacement for the cooler right away, which would bring the AMD CPU close in price to Intel at that time. I think Ryzen 1600 runs at the temperature close to i5 4690k and would do fine with my Hyper Evo 212 plus cooler.
I have the laptop from which I am writing right now so I am not in a big rush, but want to get my main system back working.
If I said something that does not make sense, I welcome the feedback.
Thank you.
P.S. AMD had AM4 for a while. A few of its new processors come with TR4 sockets. Are TR4 sockets a standard from now on or is it just an appendix for a few of its flagship processors and AMD will continue to use AM4 in the future?
