Okay, I'm new to building computers, but I took a lot of care when assembling my parts (and used an antistatic wrist strap). I haven't yet installed an OS. First I'll list what components I have:
Intel i5-2500k (with stock cooler).
Asus P8P67 Intel P67 B3 Revision.
Corsair Vengeance 8GB (2x4GB) DDR3 PC3-12800C8 1600MHz Dual Channel
MSI ATI Radeon HD 6850 Cyclone Power Edition 1024MB GDDR5 PCI-Express Graphics Card
Samsung SH-B123L
Western Digital Caviar Blue 1TB SATA 6Gb/s 32MB Cache
Zalman Z9 plus case
Antec HCG 620w
There are four main issues I seem to be having:
(1) CPU overheats (shows 97 degree C)
(2) On the first 'info' screen at bootup, I get a "Hard disk not detected message"
(3) PC almost always turns on, turns off, then turns back on again when booting.
(4) Side case fan is annoying loud (sounds like its catching on itself maybe?) It certainly doesn't help calm the nerves when turning it on.
(1) Regarding the CPU overheating; I think this is my fault. When I turned it on for the very first time, I hadn't got the cooler in properly, so two of the pins came lose when the fan came on. My impression was this spoilt the spread of the stock paste, and was probably the reason for the same 97 degree C on subsequent boots.
After initially correctly attaching the cooler, I subsequently took it off again, and then put it back on; this seemed to have some effect, and temps where at 65ish, when i got into the BIOS, but would rise into the red after about 60 seconds.
On account of this, I felt sure that replacing the thermal paste would alleviate the overheating worry. I ordered some AS5, that came with some paste remover and primer as well. I removed the paste from the cpu and heatsink, and then applied the AS5 to the cpu as seen in videos, put the heatsink over it to spread the paste and locked it in place.
However; the cpu temp is only around 60ish now, and it still steadily rises (it went to 75 after about 5 minutes). I don't know if theres something I've done wrong, or if I used to much or too little paste, or didn't clean the surfaces well enough or what. I'm very confused and a little glum.
(2) Hard disk not detected message: It seems pretty well connected, and in the BIOS the make/model is recognised in the boot options section.
(3)PC starts up, and all the fans come on, everything seems to come on; then the fans seem to go quiet, and the system seems to reboot and then work as normal.
(4) Noisy fan. If I turn it on with the side panel off, and tilt it from 90degrees, to say 80degress (towards the case/inwards), the fan 'rattleing' stops.
Well, I think thats everything I can think of that might be useful right now. I'd appreciate any help anyone can provide.
Daniel,
Samsung SH-B123L
Zalman Z9 plus case
Antec HCG 620w
Daniel,
