Hi
I have spent a while now looking at other build threads and reviews etc and have decided to go ahead and build my first ever HTPC
I have a decision to make and was hoping for some advice, i was going to go with the following spec.
Gigabyte GA-MA78GM-S2H 780G Socket AM2+ onboard VGA 8 channel audio mATX Motherboard
Sapphire HD 4670 512MB GDDR3 Dual DVI TV Out PCI-E Graphics Card
Antec Fusion Remote Veris Silver MATX Media Center Case - No PSU
AMD Athlon 64 X2 6000+, AM2, Dual Core, 3.1GHz
500 GB Samsung HD502IJ Spinpoint F1 Harddrive
4GB (2x2GB) Corsair TwinX XMS2, DDR2 PC2-6400 (800)
520W Corsair HX Series Modular PSU
Scythe Mini Ninja Heatpipe CPU Cooler
LG GGC-H20L Lightscribe SATA 16xDVD±R +RWx8/-RW x6 Also READS - Blu-Ray & HD Disc's black - Retail
The reason i have selected the Graphics card is because i understand the Gigabyte motherboard onboard graphics have caused alot of problems with certain televisions.
Some suggestions on the specification would be very helpful and weather or not it would fit in the case!!!
Do you still get a greta picture when using an HTPC for blu ray instead of a blue ray DVD!!!
