- Jan 23, 2013
- Oklahoma, US
- Thread Starter
- #121
Though, I haven't done any BIOS updates. I've never had a lack of updates there cause the BSOD. I should check on those.
I don't have one yet, but that's an excellent idea. As it stands, I'm figuring I'll have to drain my res first, then kind of.. Reverse-prime the pump. Then, pull the res out, let it hang over the sink, disconnect the hoses and let it drain into the sink.
haah yea, this is one of the things that came to mind when im designing my loop, especially after i was going to break it into steps, i wanted to make sure i had and easy way to drain so im going to put in a drain plug on first build so i can easily drain it when i upgrade my video cards and add them to the loop.
Wow that is sad. You should try looking around more and talking to people before making a purchase like that.
Jack
Best CPU Coolers
Not entirely sure who this is in reference to... But, lets operate under the assumption that it was to me.
I look around. I looked around for an entire month.. I talked to people here, for an entire month before I purchased anything. The lack of a valve to empty things is just a small oversight. It's not 'sad', since there are many people that don't use the valves. It's more a matter of convenience, and it's something I'll be adding in soon enough.
You're new to the forums, so welcome.. By try not to knock people.
Mm. I did a lot of reading over the course of a month.. Looked at more pictures of other peoples loops then I care to admit, and a leak valve wasn't something I ever saw and was like "Lightbulb! I need one of those!"
It's kind of like buying a car. You spend a lot of money on it, and then a month down the line, you want to buy a bug shield for the hood. Just something extra to make things more convenient.
Lyian, what are you thinking of doing as far as your valve goes? Have you looked into the options, yet? I know what I want, but I don't know if it exists. I'm thinking of a T-valve, with the tubs connected to opposite sides.. Then the third line having an on/off valve, so I can have it turned off, meaning that the water is contained to the tubes. I can then hook a tube up to the third port, hang it inthe sink, and turn the valve on, letting the water empty out.
Not sure if it exists though, and I'd want something that looks nice and isn't to obvious.
Hm. I'm sure the answer to this should be obvious, but I'll ask anyways.
If I'm adding something to my loop, and I can do it without emptying out my GPU block.. Is it alright?
If it don't spill.
Or, if you're adding something to your loop, should you always drain it completely?
If it don't spill.
I was also looking at the QD things, but I'm not clear as to how they work... Could you explain those, or point me to something that has an indepth explanation?
Geeze, OKAYYY. The female end and the male end when connected have flow. They restrict flow, not an issue for a drain. When disconneted they stop any water drip, flow etc.
Like.. if I have a QD on the res, will I need 3 halfs? A half for the res, a half for the tub to connect to the res, and a half for the drain line?
You need a MALE and FEMALE. The drain tube you ONLY use when it's time to drain has a M OR F and the other end of the tube is nekkid to the sink etc. Nothing but nekkid tube.
When I disconnect a QD, does it stop the water from draining untill something is plugged back in?
Geeze.... Yes.........
