I just completed my second PC build. Im new to the forum, and fairly new to overclocking. I was hoping to get some kind replies from the veterans here with good advice.
I currently have my 4770K Haswell at a stable 4.5ghz (not delidded)
The lowest possible voltage I could use to keep this stable was 1.24375
My CPU cache ratio is also at 45X
My RAM is set to XMP profile after overclocking to the usual 9-10-9-27 1866
I had to uninstall the ASUS AI Suite 3 because it seems to keep over-riding my bios settings.
Once I uninstalled AI suite, I kept crashing when opening CPUZ. I realized that even though my digi load line was set to auto in the bios, AI suite kept it at the "extreme" setting.
I then took it off of auto in bios to level 5... better, but crashed.
It wouldnt stabilize until I set the LLC to level 6.
Is this ok? Is this dangerous? Thats my first question.
My second question is -
I am always at 4.5ghz. If its changing at idle, how do I see this? I dont want to redline my engine at a stop light ya know?
Third question-
If it is in fact staying at a static 4.5ghz, how do I make it drop during idle or low usage?
I tried disabling manual mode in the rog bios, and setting both the voltages to "adaptive" , but when I did, I couldnt even get the PC to post (couldnt even get to bios). Had to CMOS it, reset everything as listed above... but I dont know if my voltage is adapting or not.
Help
EDIT:
My build is -
"Umbrella Corp"
Corsair 350D
ROG Maximus Gene
4770K
H100i (sp120's) (push exhaust)
Vengeance Pro 1866 rated
af 140's in the front
ad 120 in the rear
SLI evga gtx 770 classified's 4gb's
ax860i psu
all red and white corsair sleeved cables
And of course... an umbrella corp logo with matching boot screen log in
Third question-
Help
EDIT:
My build is -
"Umbrella Corp"
Corsair 350D
ROG Maximus Gene
4770K
ad 120 in the rear
ax860i psu
