I have three boards in front of me, bought at different times, and all have plastic levers. I don't think metal or plastic has anything to do with revisions, it's just whatever batch of sockets was available at the factory at the time.
Also keep in mind that your ram has a LOT to do with an overclock. Everybody's saying my board can do this, mine that, but we are all using different ram. Unless someone has tested the exact same components with maybe 4 boards from each revision, you can't say for sure one revision is better than another. Then there's board-to-board variation.
My first board has all the mosfets and was bought a year ago. It has the plastic lever and does 228, 2-2-2-5 out of box, box stock. But this is 1GB XMS3500, and with the max 2.96 VDIMM of the board, you will not get much higher. Same ram has gone DDR500, 2-2-2-5 on P4 boards with 3.2 VDIMM. On the 8RDA+, where max VDIMM is 2.86, sure enough, I max out at 220-223 or so.
I just got what I thought was an old board (since I thought they were better), but nope. It does not match any description 'cept maybe Rev. 2.4. Got it in Japan. It has plastic lever, missing mosfets EXCEPT the ones at the bottom of the board, teal green IDE slots and black floppy, with blue/purple DIMMS with small latches. Haven't checked it out yet, but I will use exact same case, components, CPU, and ram as my first board.
You'd think the later the board, the more stable, but hard to believe missing mosfets increase stability. I thought my first board was Taiwan, but nope, both boards are made in China.
