- Feb 7, 2005
As my title suggests I am thinking about buying a new GPU, the reason is,
Within the last 4-6 months I upgraded to Windows 11 and as soon as I did within days I started to have problems with my monitors ( mainly one monitor but did happen on other a few times ) My screens would go black for about a second about 1-2 times a day. My first thoughts was my GPU since both monitors were affected but only one on a regular basis. I thought the odds of both monitors or both GPU cables to monitors going bad at the same time that I upgraded to windows 11 was not realistic. So my first thought is maybe something is going on with my GPU. Then I found out that there is a known issue with Windows 11 "Black Screen of Death" So I did a fresh install of Windows 10 since it was past the time I could revert back. Now I still have the monitor going black for a second but now it is only every 2 days or so. So now I will start to change parts out for new ones starting with my GPU
It's 5 years old, it was the only part in my rebuilt that I used from my prior build. It's older than the rest of my system. So I would like to look at buying a new GPU The current one in my signature worked fine for my needs so it would make sense to get something more current but not a ton more powerful. I would prefer a GPU that has 2 HDMI outputs so I can just use HDMI cables directly to my monitors. Currently I use DVI to HDMI
I would appreciate some suggestions and as in the last time when I asked for suggestions on my new build, I take all suggestions and then decide what I want. I appreciate everyone's input. and thank you in advance.
