- Jul 7, 2002
- philly pa
presler is dual and cedar mill is single cpu? correct?
same chips? same cache? same process?
so if im using the computer to only watch movies, play games and , surf the web? the cedar mill would be best?
i hear ppl saying cedar mill clock much better and more than a presler...
but i saw ross with the 930 say he can get 4ghz stable on air with presler...
sooo i mean if u had a choice between a 4ghz presler or a cedar mill that had the possibility of hitting 5ghz on air? which would be the better gaming system? would the maximum possibility of 1ghz difference be better for gaming vs the dual core at a decent 4ghz?
also do u think i will see a drastic improvement from my current CPU which is in my sig???
thanks.
thanks.
