northbridge block recommend for Intel 875
nartac
California
Everybody asked about what is the best block for CPU. Can someone kind enough to tell me what it the best northbridge block for Intel 875? Thanks
jenkx
West Coast
I use the Swiftech MCW20-P and it works great. Most NB water blocks will do fine because the NB does not get extreemly hot. Water does help it stay cooler and therfore more stable though.
SemiCycle
Hampton Roads. VA
I've been using my DD z-Chip NB block for 6 months without a problem. I believe they have replaced it with the Maze4 chipset block. As long as the block you select isn't restrictive, you'll be fine.
Albuquerque
North America
DTek makes a pretty decent northbridge cooler too, but I generally agree with the above posters: so long as it's not restrictive, you're fine. NB's dont' need a lot of cooling anyway, so a high restriction fancy block simply isn't needed. Just having the cool water run over the top of it is nearly enough...
N
nartac
California
thank you guys for the replies. In that case, I will get the cheaper of the two which is the swiftech. It will match with my MCW6002-P block.
sandman001
Just Freeze It
You'll need the adapters however.
They take it from 1/2" quick connects to 1/2" barbs for 1/2" ID tubing.
N
nartac
California
thanks, sandman001. I was aware of that and placed the order for those with the swiftech nb block :)
