- Sep 10, 2002
- Baton Rouge, LA
Running stock at 1800MHz 133/33/166DDR, I picked up some steady state readings which may help y'all make a decision or two:
Using 'Hot Potato.exe'
AMD XP2200+ 256M/2700
Volcano 9 /w/ A7S333
09/08/02 - Degrees C
CPU/MB:delta:Fan setting - load
52/27 : 25 : Low setting - idle
57/27 : 30 : Low setting - full load
46/29 : 17 : Mid setting - idle
51/29 : 22 : Mid setting - full load
40/30 : 10 : High setting - idle
43/30 : 13 : High setting - full load
In my opinion, the adjustable fan ROCKS! You can adjust it to 'just cool enough' and 'just quiet enough' to tune in on a good optimum.
This is with a single 92mm Sunon at the rear sucking out, no major case ventilation. At the low and mid settings, the fan can NOT be heard over the case & power supply fans. At the higher setting, it sings pretty good though. Nothing fancy on the grease here, just what it came with.
I always see numbers quoted at the CPU and not the MB. That kind of non-info doesn't tell you anything about the CPU cooling fan/sink capacity, does it? Hopefully this info above will be more useful, since it gives you an idea what the elevation of CPU temperature will be for a given ambient temperature and fan speed. I didn't report the actual RPM. Oh well, the middle setting was in the 'middle'. I ran the little potentiometer out to the front of my case. It just reached, and is sticking out at the front of the CD-R braced by the case inserts.
