- Aug 9, 2001
- Vancouver BC
I recently reformatted and installed WinXP pro. After installing 30.82 drivers, I recieved the following error message on bootup
"The procedure entry point ThunkConnect32 could not be located in the dynamic link library KERNEL32.DLL"
How can I get rid of this error message? Once I click OK everything seems to run just fine, I would like to keep that from poping up on every boot without going to msconfig to change my startup procedure because thats just hiding the problem, not fixing it.
Here is the history leading up to the error message.
upon installing the video card (Geforce2 MX chipset) I did recieve the error message, something about missing NVARCH32.DLL from the system folder, (click OK and everything seemed OK but I wanted to get rid of it) anyway I found that file in my c:\Nvidia folder and copied it to the folder that said it was missing from(c:\windows\system32), that error message disappeared.
Now I get the new error message and I cannot find any file by that name on any of the drivers disk.
I'm assuming that i get this error msg because i manually copied the file into the system32 folder because when i take the file out i go back to the 1st error msg
If you need any system specs, its in the sig.
