- Feb 19, 2008
- Preston
Ok, I recently built a new system and decided I'd try to overclock it a little. The spec is as follows
- Q6600 G0
- Thermalright Ultra-120 Extreme (with Scythe 1600rpm 120mm cooler)
- ASUS P5K Premium
- 4GB OCZ Reaper
- BFG 8800GTX OC2
- Antec Nine Hundred
- OCZ GameXStream 700w PSU
- Vista Ultimate x64
Anyway I upped the FSB in BIOS to 333 and left everything else on AUTO - this gave me a nice 3.0GHz. I ran Prime for a bit and it didn't go that far into the 40's. All 4 cores seem to idle between 25 and 30 and usually hit low 30's (HWmonitor/Speedfan) when playing games like Crysis and COD4. Oh, this gave a 1500 increase in 3dMark 06 too.
Here is a picture of CPUZ showing the 3.0GHz overclock. As the voltage is on AUTO I guess it's pretty high? (although it seems cool enough)
Here is a picture of the temps at idle
My main question is about RAM. I've searched around all over but can't quite get certain on things (well, not certain enough to mess with mine). As I said, everything else is left on AUTO. My RAM is this. Here is a screen of the 'memory tab' in CPUZ - does this look right? This is where I get a bit lost...
Sorry if you've heard all this before but I've done loads of reading up and can't quite get my head round messing with memory speed/voltages and the whole 4-4-4-15 etc (and what affects that) - any advice would be much appreciated. I'm not just diving straight into a new thread without searching, I've spent a while reading. I'm really pleased with the computer as it is now, it's running super fast but I thought I'd just see what you guys thought of the setup and if you'd change anything
Thanks, much appreciated
- Q6600 G0
- ASUS P5K Premium
- 4GB OCZ Reaper
- BFG 8800GTX OC2
