OC'd 1600+ What are your Temps
ronin1967
Highland Park, NJ
Air, water, whatever, just let me know and as always the more detail the better...
My rig(in my sig)
Air 1600+ AGOIA 0226Z 166FSB 1.78 Vcore 2.82 Vdimm
Case 35 CPU 41
Water(in sig). It's an AGOIA Y 0213
1600+@2009 MHz 2.13v Vdimm 2.8v
It obviously depends on ambient but usually around 51C load On-die
air slk-800 =80mm 75cfm fan
agoia-y 0213=2004mhz at 2.05v at 49-53c load
aroia-y 0220=2046mhz at 2.2v at 52-55c load
agoia y 0213 XP1600
Epox 8KHA+ with vcore, vdimm and mosfet volt mods
Enermax 431w psu with pot added for adjustable 5v line
Water cooled by Swiftech:D
Usually right around the 2 Ghz neighborhood but I have been playing today.......
Last few weeks: 1982mhz (11x180) and 38c cpu temp, 2.1v vcore, 3.4v vdimm
Now: 1879mhz (10.5x179) and 40c cpu temp, 1.9v vcore, 3.4v vdimm
High ambients today led me to play with stuff, so I do not have the system running anywhere near as well as it can right now.
***EDIT:
Temps are always 100% load thanks to Seti and Folding :D
10.5 X 172 FSB @ 1.85 1806 MHz running 40c with 32c case temps Water Cooled..(heats on ;) )
agoia 0223 "4" at 166fsb locked at 10.5 in an epox 8k5a2
on air. 2 intake, 2 exhaust (80mm vantec stealths and plain-jane antec generics).
sk7 w/ ys tech variable on max w/ as3.
vcore 1.825
vdimm 2.7
case 30C, cpu 40C idle (46 load on prime), room temp 26C measured in MBM
deadseasquirrel
AGOIA-Y,0212, SLK-800 with 80mm fan(50cfm)
Wow, your either living in subzero conditions or their is something seriously wrong with the On-die readings. Thats really on the 8K3A+? Nice overclock anyway.:)
XP1600 AGOIA-Y week 13
1596Mhz (10.5X152)
35C idle
38-40C Full load. Toast for 2 hours on high priority.
1.75Vcore
i know i can do alot more but i'm using a Dragon Orb 3. soon i should have a SK7 or SLK-800 (the SK7 looks like a better deal)
1596Mhz (10.5X152)
35C idle
1.75Vcore
get the 800 and that chip should do between 1850-1925
