- Nov 19, 2002
- In slots 2 & 4!
I didn't see many posts on these DDR Boosters from OCZ. The first thing I noticed is that OCZ's list of compatible motherboards is missing quite a few of the popular boards. I am going to post the OCZ Compatibility chart, then add to it when people tell me that it works with their board. The boards that are marked in BOLD are the ones that have been added.
Abit KV8 n/a N Not Compatible
Abit IC7 3.6V
Y Board may need VTT mod for best performance
Abit IC7 Max3 3.4V
Abit AN7 3.4V
Y Use in DIMM Slot 3; results in single channel configuration
Abit IT7 MAX2 2.8V
Y Does not run above BIOS voltage setting of 2.8V
Abit AI7 3.4V
Y
Abit NF7 v.2 3.4V
Abit NF7S v.2 3.4V
Y Use DIMM slot 3
ASUS A7N8X n/a
N Functional up to 2.8V. Due to overvolt protection, voltage beyond 2.8V yields precarious results.
ASUS A8V n/a
N Not Compatible
ASUS P4S533 3.4V
Y Will o*nly fit 1 memory module
ASUS P4C800-Deluxe 3.6V
Y
ASUS P4P800 3.4V
Y
ASUS P4C800-E 3.6V
Y
ASUS P4R800-VM 3.4V
Y
ASUS K8V 3.4V
Y Will o*nly run 1 module in slot 2 or 3.
Aopen AK89max 3.4V
Y
Biostar P4VTB 3.4V
Y
Biostar K8NHA Pro 3.4V
Y
Biostar K8VHA PRO 3.4V
Y
Chaintech VNF3-250 3.6V
Y Will only fit one memory module in conjunction with DDR Booster.
Chaintech ZNF3-250 3.4V
Y Will o*nly fit o*ne memory module in conjunction with Booster.
Chaintech ZNF3-150 3.4V
Y
Chaintech 9CJS n/a
N
DFI 875LP rev.B 3.1V
Y Will not boot above 3.1V.
DFI 865PE 3.4V
Y
DFI nForce2 Lan Party rev B n/a
N
Epox 4PCA3 n/a
N Not Compatible
Epox 4PCA3I n/a
N Not Compatible
Epox 8K5A2+ 3.6V
Y Use Booster in DIMM slot 2 or 3
Epox 8RDA3+ 3.4V
Y Use Booster in DIMM slot 1 or 3. Dual Channel unavailable in conjunction with Booster.
Epox 9NDA3+ n/a
N Not Compatible
FIC 875Dynasty n/a
N
FIC P4M-RJ300 n/a
N Not Compatible
Gigabyte 7N400 Pro 2 3.4V
Y
Gigabyte 8KNXP 3.1V
N
Gigabyte K8NNXP 3.4V
Y Can o*nly fit o*ne memory module w/o heatspreader
Gigabyte K8NSNXP-939 3.7V
Y
Gigabyte K8NS Pro 3.5v
Y
Leadtek NCR18-D Pro2 Ltd. 3.2V
Y
Leadtek K7NCR18-D 3.2V
Y
MSI 865PE Neo 3.4V
Y
MSI K8N Neo2 Platinum 3.4V
Y
MSI 875P Neo 3.3V
Y BIOS already adjustable to 3.3V. Will not function reliably beyond this voltage.
MSI K7N2 3.3V
Y Will not boot above 3.3V
MSI K8T Neo 3.4V
Y Can o*nly fit 1 memory module
Shuttle AN50R n/a
N
Soltek Qubic 3801 3.8V
Y Booster will not fit with drive bay cage installed.
Soltek SL-865PE 3.0V
TBD Will not boost above 3.0V
Mine worked like a champ on my Gigabyte K8NS Pro board that usually limits me to 2.7 volts. I can send as much as 3.6 volts to my ram now, but I leave it at 3.0 volts. This .3 volt increase has allowed me to go from 170mhz 2-2-2-6 to 225mhz 2-2-2-6 with my BH-6 ram. I think that is worth $50 dollars, and I am super happy with my purchase. What have others found about this OCZ DDR Booster?
-Collin-
Abit IC7 3.6V
Abit IC7 Max3 3.4V
Abit AN7 3.4V
Abit IT7 MAX2 2.8V
Abit AI7 3.4V
Y
Abit NF7 v.2 3.4V
Abit NF7S v.2 3.4V
Y Use DIMM slot 3
ASUS A7N8X n/a
ASUS A8V n/a
N Not Compatible
ASUS P4S533 3.4V
Y
ASUS P4P800 3.4V
Y
ASUS P4C800-E 3.6V
Y
ASUS P4R800-VM 3.4V
Y
ASUS K8V 3.4V
Aopen AK89max 3.4V
Y
Biostar P4VTB 3.4V
Y
Y
Y
Y
Chaintech 9CJS n/a
N
DFI 865PE 3.4V
Y
N
Epox 4PCA3 n/a
N Not Compatible
Epox 4PCA3I n/a
N Not Compatible
Epox 8K5A2+ 3.6V
Epox 8RDA3+ 3.4V
Epox 9NDA3+ n/a
N Not Compatible
FIC 875Dynasty n/a
N
FIC P4M-RJ300 n/a
N Not Compatible
Y
Gigabyte 8KNXP 3.1V
N
Y
Y
Y
Y
MSI 865PE Neo 3.4V
Y
Y
MSI 875P Neo 3.3V
MSI K7N2 3.3V
MSI K8T Neo 3.4V
Shuttle AN50R n/a
N
-Collin-
