Hey everyone, I've been out of the fold for awhile... but I was in the mood to do some overclocking.
Basicly, my goal is to get my system stable at around 2400-2500mhz, specs are as seen in sig [minus the overclocks, which proved to be unstable long ago].
My current issue is with getting the memory stable. I've based the config of my memory settings around what I found on the OCZ forums, but no dice.
Heres the current settings:
I know many of you have run similar hardware in the past, so perhaps there is something I'm missing you might see. Thanks for the help.
Freq set: 200 [1/1]
CPC: Enable
Tcl: 2.5
Trcd: 04
Tras: 08
Trp: 04
Trc: 08
Trfc: 16
Trrd: 03
Twr: 03
Twtr: 02
Trwt: 03
Tref: 4708
Bank Interleave: enabled
DQS Skew: auto
Skew val: 0
DRAM Drive Strength: weak 4 [have tried weak 2 and weak 3]
Data Drive Strength: Level 2
max asyn: auto
dram response: normal
read preamble: auto
IddleCycle: 256
Dynamic Counter: Disabled
R/W Bypass: 16x
bypass max: 7x
32 byte Gran: Disable
FSB Freq: 250
LDT/FSB: 4x
Transfer Width: 16 16
CPU/FSB: 8x
PCIe: 100
CnC: disabled
Startup: 1.475V
CPU VID: 1.4
VID Control: 110%
LDT Volt: 1.3
Chip Set: 1.7
Dram: 2.8
+.03V: disabled
