- Jul 1, 2003
- Grand Rapids, MI
On my ASUS A7N8X-E Deluxe I had a Barton Mobile showing up as "Unknown CPU type" and it locked the voltage at 1.88 volts and whats weird is that setting the FSB at like 200Mhz and the Multiplier at around 12.5 or 13 resulted in it showing up as a 866Mhz or 900Mhz "Athlon Mobile" both in the BIOS/Boot/and windows. But if I backed it to 133 or 166FSB with a multiplier of 13 or less, it would run at the correct speed, all the way up to about 2.6Ghz, which it was seeing temps of about 63-65C load, with a Jet 7 Coolermaster on Full Power & Arctic Silver. A multiplier of 13.5 or 14 also resulted in the same drop to sub-Ghz speeds and the mobile name showing up. It would not let me choose any other voltage than 1.85 no matter what settings I chose. What is wrong here?? I am sending the CPU back because the board just won't take it, and I'm awaiting an AthlonXP 2800+ replacement/exchange, (the CPU's code numbers on the chip are "AXDA2800DKV4D", "9679123430603", "AQXCA 0347APMW") hopefully not to face the same problem again. Any ideas why this is happening? I am assuming its an unlocked CPU as it is shown as a Mobile Barton by CPUid. I would have been perfectly happy had the voltage issue not been there, it still ran stable with the 1.88 volts at 166FSB x 12.5 multiplier (2.08Ghz) which isn't even 2800+ speed, but at a temp of about 59-62C idle/load. I just don't get whats wrong here and think its going to happen again with the replacement. Is it the board?!
