This is what I have so far, minus the actual case. I need to build a budget system that allows me to use an AGP card, and I need to order it tonight! I am also re-using parts (drives, monitor, videocard, KB/M, OS) from an older computer to complete the system. Are there any conflicting parts with the following?
PS: Please suggest different parts in the same price range, if you have any in mind. This will NOT be an overclocking system for at least a while. I'm going to have to wait to see what that Venice can really do.
Thank you very much for your time.
ASRock 939Dual-SATA2 Socket 939 ULi M1695 ATX AMD Motherboard - Retail
Model #: 939Dual-SATA2
Item #: N82E16813157081
In Stock
$69.99 $69.99
Update
FSP Group (Fortron Source) AX400-PN, 12cm FAN, version 2.0, 2 SATA, PCI Express, 400W Power Supply - Retail
Model #: AX400-PN
Item #: N82E16817104953
In Stock
$39.99 $39.99
Update
AMD Athlon 64 3200+ Venice 1GHz FSB Socket 939 Processor Model ADA3200BPBOX - Retail
Model #: ADA3200BPBOX
Item #: N82E16819103535
** This item is warranted through the product manufacturer only. what's this?
In Stock
$169.00 $169.00
Update
CORSAIR XMS 1GB (2 x 512MB) 184-Pin DDR SDRAM DDR 400 (PC 3200) Unbuffered Dual Channel Kit System Memory Model TWINX1024-3200C2 - Retail
Model #: TWINX1024-3200C2
Item #: N82E16820145449
In Stock
$105.00 -$6.00 Instant $105.00
Update
Maxtor DiamondMax 10 6L200S0 200GB 7200 RPM Serial ATA150 Hard Drive - OEM
Model #: 6L200S0
Item #: N82E16822140168
In Stock
$90.50 $90.50
Update
NEC Black IDE/ATAPI DVD Burner Model ND-3550A - OEM
Model #: ND-3550A BK OEM
Item #: N82E16827152058
