Hello guys,
I have searched for threads and fourms on how to overclock the phenom II X4 955. Most of them were useful but the OP's that started those topics failed to return to describe their results. Anyways, I know the 955 is an older cpu and every one is on about the new FX lines but I still haven't jump ship away from the AM3 socket yet.
Getting on with the point. My zalman cpu cooler just died and to replace it I just got the Corsair H100i water cooler. My temps, at stock settings, is consistent at 33-34c idle and 41-42c full load (currently 30c ambient). Before with the Zalman it was 48-49c idle and 55-57c full load....I never dared tried over-clocking lol.
So now that I have a water cooling setup I have started to try overclocking which I haven't done since my old Pentium 4 2.4 ghz Northwood socket 478 (got that sucker up to 3 ghz )
With setting the CPU vcore to 1.425 volts and the cpu multiplier to 19.5 I managed to achieve 3.9 ghz stable (38c idle and 46c full load). I did manage to get 4ghz with the multiplier at 20 but when I tired to run starcraft 2 my system BSOD.
I hadn't tried anything else. Right now I have my system back to stock settings. My goal is to hit 4 ghz. I am sure it can do it but i could use some help getting there. Can anyone help me with this please? My system specs are as the following:
Case: Antec 900
Motherboard: Gigabyte 790XTA-UD4
CPU: Phenom X4 955BE 3.2Ghz C3
Ram: Corsair 8GB DDR3 1600 mhz (stock speed)
PSU: Corsair HX650 (650 watt)
Video: XFX HD6850
Cooling: Corsair H100i (push config) modded to fit inside case
HDD: WD-500GB Black edition
OS: Windows 7 Home premium
Thank you
Case: Antec 900
Video: XFX HD6850
Thank you
