- Dec 14, 2010
Yes, once again it is time to overclock another socket 939 CPU.
This time up on the test bench is the AMD Athlon 64 3000+ Winchester D0 stepping (ADA3000DIK4BI).
I'm starting this one out the same way I always do, seeing how fast it can go at stock voltage, and then raising the voltage up to go further.
1.8GHz (stock): 1.36V
2.0GHz: 1.38V
2.2GHz: 1.46V
2.3GHz: 1.55V
I am impressed by how cool this CPU runs. At idle with stock frequency and voltage I'm getting 27-30°C, and at load around 33-34°C. While overclocked it has come up a little bit to 29-32°C at idle, and 42°C under load. Still, that's pretty cool as far as I'm concerned.
It achieved a 200MHz overclock up to 2GHz with a little lower than stock voltage (1.38V, stock is 1.4V). The jump up to 2.2GHz required a bit more of a boost in voltage than I expected, bringing it up by .08V going to 1.46V.
I'm now testing 2.4GHz and it's looking like I'll hit its max pretty soon since I'm having to run 1.63V at the moment (at least enough to run SuperPi, PiFast, and UCBench 2011). I haven't tested prime95 for stability yet. I'll have to stop if it needs 1.7V or more to remain stable, since I only have air cooling and 1.7V is pretty much what I've defined as the danger zone for air cooling.
2.0GHz: 1.38V
2.2GHz: 1.46V
2.3GHz: 1.55V
