Hello there
I am trying to overclock my 4930k on my Rampage IV black edition and I am experiencing some strange issues.
My specs:
- Mobo: ASUS Rampage IV Black Edition
- Memory: Corsair Vengeance Pro Black (2x, 8GB, DDR3-1866, DIMM) CMY16GX3M2A1866C9
- CPU: i7 4930k
- CPU cooling: Corsair H100i
- Graphics card: 1x Asus R9 290X DirectCU II
- PSU: be quiet! POZWER ZONE - 1000W
So first off I tried to overclock it to 4 GHz by setting the multiplier to 40 and VCore to 1.3v.
I know 1.3v is much for that overclock, I wanted to raise the multiplier till prime95 crashes.
Speed-Step, C-States and Turbo mode is disabled.
Now I boot the windows (which works) and run prime95. After a few minutes the pc just shuts down (and i have no idea why).
After that I found out that the BIOS always resets my multipliers to 34 when I disable turbo mode??? why???
And if I reset my multiplier to 40 it enables turbo mode again automatically...
I tried all kind of settings, voltages, etc... I even tried 1.35v for 4GHz and it still shut down when running Prime95!
Also in the Digi+ section I set all capacities to 110% - 120% and cpu LLC to medium (also tried high) and all other calibrations to High... Same results.
Futhermore I tried the same thing with X.M.P mode and Manual mode. Also tried with Base clock at 125MHz... still same result...
I also raised the VCCSA and PLL voltage a bit, still not better...
This is driving me nuts (it's my first time I do some overclocking).
I think there must be something I am doing wrong, but can't figure out what. Also why does it always enable Turbo mode when setting multiplier??? This is totally nonsense to me as it makes the cpu unstable.
Can someone help me out here? Thanks
My specs:
- CPU: i7 4930k
