Hi guys, im new to the forums, well newly signed up, have been veiwing for a while now.
I am upgrading my desktop in the next week or two and was just after some advice.
Ok, at the moment my pc is as follows:
CPU : core2duo E7500 o/c to 3.6 ghz
M/B : GB GA-EP45-UD3
GPU : Powercolour HD6850 DDR5
PSU : Vantec Ion2 600w
RAM : 4g kingston 1333
HD : 1TB Seagate + 500g
MONITOR : Asus 21.5" LCD
CASE : Thermaltake V3 with 3 fans
Im looking to upgrade to quad core and run dual GPU's via crossfire, so obviously i need to change, well basically everything lol..
I mainly use it for gaming (BF3 at the moment) so i want something that will run a bit quicker for me, but im on a bit of a budget.
Was looking at getting an i5 2500k 1155pin CPU (its within the budget)
and hopefully use my ATI 6850 and buy a second one, heres where im stuck.. Most mobo ive looked at have a Pci-e 3.0 and a Pci-e 2.0, so, can i still use the 6850 (supports 2.1) in a 3.0 slot? If not, can i get a 6950 and run it with the 6850 with crossfire? looking at this mobo Asus P8Z68-V GEN, or could you maybe suggest a diff mobo that will do the trick, i probably will o/c it a little but nothing too drastic.
Anyway, thanks in advance for any help and i hope i posted in the right place
