mustangman said:I guess I'll try it again. I didn't notice right yesterday when I posted that it didn't work.
Third time's the charm?
Did you have two seperate loops? I wan't able to tell how you had that setup.webmedic said:you may be looking for something like this:
http://community.webshots.com/album/31101133jPbxaXIYoy
This was my first version. I'm currently on my 3rd version of this design but I will say that using pelts in the water system is a nice addition to a regualar water cooled setup but it's dificult to get it perform by istself. The next version being worked on is a dual 70watt pelt model with dual heatsinks and fans. It should perform ok but I have also started to look into other ways to get good temp.
With just a pelt you will find that your temps will continue to creap on you even after many hours. I will say however that toast (the program I used to heat up the cpu) is brutal. It gives temps about 3c higher than prime95.
DOH! specs: 180gph pump and 120watt pelt. The two heatsinks are bolted together and the res is designed to have the return flow directed towards the center of the chill sink.maskedgeek said:are those heatsinks epoxied together? if not use a bigger one in the rez,
and is that chiller epoxied to the container? if not turn it 90 degrees, and run the water in the side so it swirls around and around inside the box so it gets more movement around the heatsink.... thats my idea, basicly the same as what you have there,
what wattage pelt is that?
and how many gph pump do you have in that thing?
Alot of people who have never used a pelts come up with ideas like this. Yes this will take care of cooling your water temps and probably give below ambient water temps at full load. But will add a few drawbacks for ya.Jokke said:
Some drawbacks I have come up with so far; It is rather expensive to build: Four TECs = $$! Shaping the coldplate require a CNC mill (I guess that few people have such a machinery in their basement/garage?)
And of course condensation - IF it works and goes a few degrees below ambient temperature!
Some advantages; I'll guess that it would require little labour to exchange the normal radiator in an existing watter cooling rig.
3D image of my design
I'll be grateful of any ideas, comments or suggestions on this setup.
Regards, 'Jokke'
racecar12 said:Alot of people who have never used a pelts come up with ideas like this. Yes this will take care of cooling your water temps and probably give below ambient water temps at full load. But will add a few drawbacks for ya.
608watts of heat>higher than the lowest setting on an electric heater.
Energy consumption>Not much lower than what my house consumes.
Cost of setup>could have gotten a vapo-chill if not right now in a few months.
Sorry Jokke
flounder43 said:I also would like to see a thermostat built in, so that you could monitor the temp of the water and perhaps cycle the pelt between on and off so that the water is cooled, but not to the point where it develops condensation.
