I have been using a GW FOP-38 for a couple months now and I am thoroughly deaf. I have some plans to build a quieter rig. I was considering a Hoot Chute, but I have some reservations. One reason is because my machine is in a cabinet that limits how wide it can be. The front and back of the cabinet are open, though, so I am able to create good front-to-back airlflow. I like some of the designs I have seen where a 80+ mm fan is funnelled onto a heatsink. These larger fans turn slower, and the focusing effect of the funnel probably overcomes the dead spot right below the motor.
I have an Enlight 7237 with an ASUS A7V mobo and a stock T-Bird 900. I need some help deciding what heatsink I should start this project with. Is the one I have good enough? If I step up to another, which? One friend recommended an Alpha, but I know that dozens of new HS's have hit the market lately and Alphas may not be #1 anymore at pulling heat off the chip. If an Alpha, the PAL or PEP? I am intrigued by the sideways mounted fan of the Alpha PEP66.
The fan part of the equation is a little easier, because no matter which one I choose it is almost guaranteed to be quieter than that da^^ned Delta!
Any suggestions would be most helpful.
