I am planning to buy a computer to run a heavy analytical program that uses only one cpu core. This computer will be only for that purpose.
I have a very limited budget, so I want to spend most of the money on a strong cpu, but leave everything else very basic (lower end graphic card, power, keyboard etc).
1. Enable only one or two cores, Disable all other cores.
2. Disable TH
2. Overclock that one/two cores on stock cooler to as high as possible.
Could you please recommend a CPU and motherboard for this purpose?
Should I use 4930K, 4770K, or 3770K? X79 or Z79 and what brand?
Graphic performance is not important.
The goal is to get the highest single core performance on lowest budget.
Thanks.
2. Disable TH
Thanks.
