power on without cpu and ram
augustwest
The Darkest Star
is it ok to turn the power on in my system without the processor and ram on it? i dont have a processor and ram for my most recent system i am building and i would like to turn it on to see how fans and such are working.
David
Forums Super Moderator
If you do turn it on it will probably start but you will get no response from the computer at all. There is really no point.
David
augustwest said:
wont my fans come on thought? that is all i want to do.
if the PSU comes on, yes the fans will start.
Ridenow
Sneaky Moderator
Springfield, IL
Most motherboards will not power on without a processor or memory. The most you would get is the lights might flash once and you may get a beep, but no your fans will most likely not come on. If the fans do come on it will only be for an instant, about 3 revolutions max.
Go ahead and try it. Nothing will be damaged, just nothing will happen.
