- Jan 5, 2005
- Ormond Beach, FL.
I have been working on this for three months. Every time I would stick a motherboard with all the w/c components in a Lil Devil case, memory slots wouldn't work or a GPU would only run at 8x when it should have been 16x. I give up on Lil Devil cases. They are just two flimsy the way the motherboard mounts.
This CaseLabs STH10 is not. This has to be the best quality case I have ever seen. It's not heavy at all. It has a removable motherboard tray and that sucker is not going to bend in any way, shape, or form. It' the only tray I have seen that has the tray and a back plate to the tray that makes it even sturdier.
It's still not finished. I'm still waiting for the pedestal that will give it space for two more 120.4 rads and wwill make it about 6" taller. I also have more radiator mounts coming and the stand with heavy duty casters.
This was three hours of my time. You have to build it yourself and nothing comes with it, no fans, no ports, no radiator mounts, no fan mounts, no nothing. All have to be purchased separately.
That big box in the background is how it comes shipped. Every piece is meticulously wrapped. The hardware bag had to weigh 10 pounds. All the hardware was marked what it was. They need to do the same for the case parts. Some are obvious what they are, but some aren't. You need to look at the instructions to figure it out.
