- May 23, 2001
- Asteroid B-612
- Thread Starter
- #141
I don't have a spare oven, compressor, painting equipment, supplies, sand-blasting gear, or a dedicated space where I can do it. So it's worth the $50 to not have to do all the extra work with the potential of it not turning out as well.Angel-of-Sorrow said:Do you not have the things needed to do powder-coating, or do you not know how? Or is it just easier to get someone else to do it? lol
I used 1-inch long stand-offs in the upper most motherboard mounting holes and then bolt the cover onto those.Angel-of-Sorrow said:Also, what's inbetween the PVC motherboard cover and the motherboard? Do you make hollow dowel fittings and just get longer screws to reach the motherboard stand-offs?
Covered the plastic sheet in masking tape, traced the original cover on the masking tape using a fine-point sharpie, then used the drillpress and scrollsaw to cut out the marked shapes.Deadbot1_1973 said:exactly how did you cut the openings in those ABS backplates Captain? Must say that those look mighty sexy.
Who is Steve?Maviryk said:Steve how much the powdercoat run you?
gangaskan said:I'm curious as to how good the powder coating holds up? I'm interested in getting this done to my case in the near future, my case panels are very scratched and want to re do them either paint or powder coat
