Proms overclocking on a KK266R...Multiplier and dividers are too DAMN HIGH!
{X-H}KnownKiller
Yeah i dont know what the hell i'm supposed to do here.. It would be nice if they would write up a bios that would let ya play with the 1/3 1/4 divider for the PCI buss like the ABIT boards did... I mean i'm trying my damnist the last week to get this thing stable at 1400 and its not happening at all even though my computer will post all the way up to 1490 at 9.5 volts..I know forsure its the dividers doing me in. I checked on Sandra and it showed that my PCI was running at over 49 Mhz... I'd like to know how i'm supposed to combat that ****.. Hell at even a FSB of 133 and a mulitiplier of 10X i was at 47 i believe.. **** i had to set it all back to normal (Default) just to get the PCI buss lowered down to 33 Mhz...
Man i think i bought the wrong damn M/B just like i bought the wrong H/S...
heh i got the ThermoEngine (Black version) with the bad *** all mighty 7200 RPM delta Screamer.. Yeah i knew that it wasnt the best but i couldnt find a place to buy the best at the time.. but i cant complain about the heat though.. I can get it down to 93 Degrees and max 107 under extreme pull..How? Well maybe 1 day i will show ya all my SUPER DUPER MODIFIED CASE OVERCLOCKER SPECIAL!!! HEHEHE WHOOO HOOO!!... Yeah baby.... hint... Its a modified HUGE air cleaner!!....Major air pull at super high speed!...
KnownKi||er]LBA[
hehehe opps...might help if i add my system stats... Been a long while since my last forum that i visited went down...
AMD T-Bird AXIA 0107GPDW 1.2 GIG @ ?? Still burning it in...but only stable at 1350 which i know its gota be because of the god damn auot dividers!!!!
IWILL KK266R
448MB PC 133
Geforce 2 PRO hopefully if i ever get the return lable so i can RMA the damn thing :( So a tthe moment its the Geforce DDR
Live! value
3COM nic 905B which i damn know that dont like no freaking outragous 49Mhz PCI buss..
40 GIG RAID setup with 2 Quantum Fireballs
Kenwood 62X
RazorBoomslang 2X on a Surface 1030 mouse pad! the thing owns YOU!
IIyama Vision Master Pro 450 19" FLAT screen
Overclockers extremly modded Air cleaner case from HELL! hehe..System temp around 70 Degrees...
KK
"all the way up to 1490 at 9.5 volts"
Man I can't get my processor to go over 7 volts :)
sorry could not resist.
What processor are you using?
keep me posted I am putting one together this weekend.
I thought the pci multiplier was supposed to be auto.
up to 133 is 1/3 and if your go over it was supposed to drop to 1/4 ?
might ask Yo he has a lot of experience with this
sparks
when you set the jumper on the mainboard to 133 bus the pci speed is reduced to 1/4 the system bus. when the jumper is set to 100 bus the pci speed is 1/3 the system bus. this is why there is a jumper there and not just 100-200 in the bios for fsb adjustments. :) I can run my cpu on the kk266-r at 170 fsb and i have a nic and soundblaster live installed. Sisoft sandra shows my pci bus at 57 mhz so Sisoft sandra IS WRONG :) As for 3com nics, I have one in my other pc that I tried to use in this system and it freaked on me at over 165 mhz or so. Try pulling all your cards out of the system except for the video card and see if you can clock higher. If you can post at 1490 you should be able to run near 1400 - 1450. Sounds like a possible cooling problem as the processor is posting but overheating before it boots. Good luck
Kriegster (Mar 22, 2001 03:44 p.m.):
That cant be right.... Sandra is telling me that my PCI is at 1/3 right now at 133 FSB...Right now the PCI is at 44Mhz....
KK
KnownKi||er]LBA[ (Mar 22, 2001 03:53 p.m.):
KK
Sandra is wrong bro. There isn't a soundblaster live in the world that will work at 57mhz :)
