hey guys, were do i find these? like the swiftech ones, but for 1/2OD tubing? thanx
JFettig Hey! I showered! Senior Joined Jan 5, 2002 Location MN Nov 11, 2002 #1 hey guys, were do i find these? like the swiftech ones, but for 1/2OD tubing? thanx
gone_fishin BandSaw King Joined Feb 11, 2002 Location U.P. Michigan Nov 11, 2002 #2 Did you check USPlastics?
Liss Member Joined Aug 27, 2002 Location Toronto: The Capital of Canada Nov 11, 2002 #3 wow.. they have everything here.. http://www.usplastic.com/catalog/ca...edfit+(r)+Acetal+Push+In+Tube+Fittings&Page=1 -edit- http://www.usplastic.com/catalog/pr...+In+Tube+Fittings%2DNPTF+Male+Pipe+Connectors
SkiFletch Member Joined Jun 24, 2002 Location Crotchfester (aka rochester), NY Nov 11, 2002 #4 also try Cole-Parmer if you want something special...
OP JFettig Hey! I showered! Senior Joined Jan 5, 2002 Location MN Nov 11, 2002 Thread Starter #5 the crazy thing is that i looked at usplastics and didnt find them, thanx guys, ill check the other place too
OP JFettig Hey! I showered! Senior Joined Jan 5, 2002 Location MN Nov 11, 2002 Thread Starter #6 so far i havent seen the 1/2 OD ones, that use smaller holes that is, like 1/4npt im hoping to be able to use 1/4npt onthese...
HighFlowRod Member Joined Sep 19, 2002 Nov 11, 2002 #7 maskedgeek said: so far i havent seen the 1/2 OD ones, that use smaller holes that is, like 1/4npt im hoping to be able to use 1/4npt onthese... Click to expand... Is this it? http://www.usplastic.com/catalog/pr...ings&product_id=Quick+Disconnect+Hose+Adaptor look here too http://www.usplastic.com/catalog/ca...tegory_name=Quick+Disconnects+Fittings&Page=1
OP JFettig Hey! I showered! Senior Joined Jan 5, 2002 Location MN Nov 11, 2002 Thread Starter #8 nope, the other guys got it rite, they have the correct ones.. i just need to find the rite sized ones...
I Iron Hawk Member Joined Jan 19, 2002 Location Groton, CT Nov 11, 2002 #9 http://www.mcmaster.com Under the Pipe Fittings and Pipe, Tubing and Fittings, Hose and Fittings click on: Quick Disconnect Hose Couplings
H hooziewhatsit Senior Member Joined Dec 18, 2000 Location Klamath Falls Oregon, USA Nov 11, 2002 #10 I just got some from a local hardware store for garden hoses.
OP JFettig Hey! I showered! Senior Joined Jan 5, 2002 Location MN Nov 12, 2002 Thread Starter #11 crap, people getitng mixed up, the same type thing swiftech uses....
natopotato Member Joined Jan 23, 2002 Location yuba city Nov 12, 2002 #12 im guesssing that perticular style of quick disconnect is not made for 1/2... probly.. eh..
OP JFettig Hey! I showered! Senior Joined Jan 5, 2002 Location MN Nov 12, 2002 Thread Starter #13 I have seen them Gone Fishin gave me a link ill have to go check out...
