Is it possible that due to not having a lot of resistance in the pump, that the pump makes a noise when a modified top is used and the barbs are at right angles to eachother?
I used to have it upset to the barbs were at right angles, but the pump used to make an awfully loud noise, so i changed it so they are next to eacother. I have a alphacool top.
The reason I say this is because I thought since the water is traveling so fast that it is hitting the impeller very hard and causing it to make noise?
Thanks
Thanks
