quick question
swiftamd
sup, just got a quick question...when you up the fsb, does that also mean that you increase the memory speed to whatever the fsb is running at. For example, if you have pc2700 but are running a fsb of 180, does everything run at 180, or does mem stay at 166 while the fsb moves up?
If the mem is running synchronously with the FSB (which it almost definitely is) then yes, it is at whatever speed the FSB is set to.
With mine its very wierd. At 166fsb(cpu), my pc2700 is at 200fsb, pushin it. I can lock it at 2100 or 2700, but thats no fun...
Yuriman, you prolly have it set for the mem to be at 166 but with the FSB higher at 166 it actualy is a lot higher becuase it works using ratios not just setting the speed
