It, as it says, keeps the voltage on the 3D load voltage. There are no risks.
I noticed this new thing that after starting my comp if i run msi combustor its shows me 200+ frames and the temp goes 100c and after some time the clock goes to 450mhz and the frames become 150+ and the temp 70+c. What is this now???
That would be throttling because of temperatures.I noticed this new thing that after starting my comp if i run msi combustor its shows me 200+ frames and the temp goes 100c and after some time the clock goes to 450mhz and the frames become 150+ and the temp 70+c. What is this now???
It sounds like your system isn't stable. High temps can be from a poor case airflow or a poorly mounted/defective gpu heatsink or both.
Crashing as soon as you load a game could be a bad gpu, a poorly mounted gpu heatsink or an insufficient power supply.
Low 12v reading could be bad software, a bad sensor, or again an insufficient or poorly designed power supply.
Kombustor is terrible for doing anything but testing cooling or killing cards. It is an awful metric for game stability and puts unreasonable stress on the cards power delivery.
If I were having those symptoms I would start by taking the side of the case off and blowing a house fan into it. That checks case airflow. I would then check that the fan is spinning on the gpu. If you are comfortable with it you can change the thermal paste and remount the cooler to see if it helps. Also let us know what the power supply brand model and specs are when you pull the side off.
Ive never heard of that psu brand before, according to the website found at http://www.e-spectrum.in/products/power-supply/es-psu-x600.html it is an old design power supply that has a large portion of its rating set aside for 5v rail, leaving only 336w on the 12v rail, which is what the vast majority of modern computers use for power. The cpu and gpu both use 12v, and they represent most of your computers power usage. That being said, if it is actually capable of its listed 336w, that should be enough to power an intel h61 based system and a 270x.
As for airflow, you just want to have a fan pointing in there while trying to play a game or run a synthetic test like unigine heaven/valley or 3dmark.
When you say the gpu is hot, how hot is it getting? They can run quite warm, and it isnt uncommon to see them hit 80-85 degrees celcius under load. If you dont know how to change the thermal paste i wouldnt worry about doing it, it may void your warranty and you dont want to do that if you can avoid it.
Without knowing anything else about your system, i would suspect its that power supply, but you can try downclocking the card, or unplugging extra hard drives and peripherals to reduce power draw if there are any.
