- May 22, 2016
- Thread Starter
- #21
I just upgraded from crossfire 7970 to 1070, its completely worth the money
You all convinced me. Pulled the trigger on the 1070.
I'm not a fan of Gigabyte, but somewhat better-quality capacitors and cooler mosfets always is a good thing. As long as you have good airflow and the card runs cool under high load, the cooler should probably be silent enough; but the 3 fans on classic WF3 could be very, very loud. Personally, I prefer 2-fan solutions with larger fans instead.
Does the 1070 out-perform the 7970 Crossfire setup noticeably?
My cfx set up scored about 15k in 3d mark with a mild over clocked 4770k and over clocked cards. The sli setup stock with with a stock 6600k scored 20k in the same benchmark. I'm curious to see how far I can really push it before I got with water cooling
Ps. I'm also running bf4 at about 190fps in 1080 versus about 90-100 with the 7970s
Your saying your running stock i5 6600k however your signature is 4.0GHz.
That's pretty impressive for a single card solution. Are those results w/your 1070 overclocked or at stock?
which 3dmark? Fire Strike? Which one? Performance?My cfx set up scored about 15k in 3d mark with a mild over clocked 4770k and over clocked cards. The sli setup stock with with a stock 6600k scored 20k in the same benchmark. I'm curious to see how far I can really push it before I got with water cooling
thats a double card setup in sli with a non hb bridge, single card was hovering around 14 to 15k mark
Thanks. But it still sounds like a single 1070 was matching 7970's in Crossfire?
Depends on...There about. I'm curious to know how much of a performance difference an i7 with ht mattered compared to an i5 on that score though.
It does respond to cores and threads, most any of them. How much depends on which 3DM and which one within the latest as to how much it responds.which 3dmark? Fire Strike? Which one? Performance?
Depends on...It does respond to cores and threads, most any of them. How much depends on which 3DM and which one within the latest as to how much it responds.
Performance I am guessing performance by the score?
